While working with XWidget I've been stumbling upon some features which would be great to have in it.
- VLC media player support
http://www.videolan.org/vlc/ XWidget Designer:
- an exact pixel ruler (a mark for every pixel)
- dragable ledger lines and/or a grid
- a scaleable preview (elements are very tiny sometimes)
- .otf font support
- text on path or at least on a circle
- letter kerning resp. the possibility to modify the gaps between the letters
- masks for fonts
- a spiral in the components
- the possibility to ad an element to a progressbar (like the thumb) which moves with the progress (as it is possible with rotators)
tiny bugs:
- there are different hand pointers for buttons and check buttons (looks strange if they are adjoin each other)
- pies do not close completely
- gradients on round lines seems not to work, it is alway a mixture of the start and the stop color but not a gradient
that's all
It would be nice if one or the other could be added in future. Anyways, thank you for XWidget, it's great
