It is currently October 23rd, 2026, 4:03 am
PostPosted: October 28th, 2012, 5:54 am
It would be great if you could add in "RSSCore" function:
"Auto show TrayBalloon when you get a new feed"
Something like this:
I'll apreciate your feedback. :D
PostPosted: October 31st, 2012, 2:51 pm
I insist... Tony, what do you think?
PostPosted: October 31st, 2012, 9:25 pm
you can use code on this I think..
It's not addiction, it's dedication... #Gaming
PostPosted: November 1st, 2012, 1:45 am
It can be ... but I'm a graphic designer who does not know a lot of codes ...
PostPosted: November 3rd, 2012, 11:32 am
Could anyone tell me how to make "Auto show TrayBalloon When you get a new feed" with a code?
PostPosted: November 5th, 2012, 11:06 pm
There is not a way to use "auto show trayballoon" function with code.
What do you think about auto unslide the slidepanel when you get a new feed?
PostPosted: November 6th, 2012, 3:36 am
It wolud be better to me!! can you do the code?
Thanks!
PostPosted: November 6th, 2012, 8:14 am
hi , I'm sorry that I forgot the showTrayBalloon("text",duration) [duration:second] function before.
You can use it to show trayballoon.
This function is available when you "run" a widget, not "debug" it.
1.9.3.928 and above XWidget version is required
Example to use this function and judge whether there is new feed.
rss.rar [13.62 KiB]
Downloaded 476 times
PostPosted: November 6th, 2012, 9:21 am
Quiancang:
I'm testing your widget. Sounds good! thanks!!
What is the 1.9.3.928 and above XWidget version?
I have notice about "1.73 2012.9.28" Version.
PostPosted: November 6th, 2012, 10:33 am
Great work! I tested it, it works perfect! (ie, when you get a new feed, widget unslide).
Thank you very much, I think it's very interesting and VERY useful this widget!
Users browsing this forum: No registered users and 247 guests
