PostPosted: October 27th, 2012, 3:09 pm
Hey Tony! when the position is set to "Keep topmost", you can not see the "tooltips" that are behind the widget automatically. Can you fix this?
Thank you very much!
And: Congratulations for the 1.73 version! It's so cooool!
Armando
PostPosted: November 4th, 2012, 6:33 am
Is there any way to fix this with a "code"? for example, can be assigned to an element of the widget (an image or a text function as "hint" or "tooltip") a superior position to "keep topmost"?
Thank you very much for any help
PostPosted: November 5th, 2012, 11:21 pm
hi,Armando, you can use "bindtooltipControl" funtion instead of "hint" function to solve this problem.
I will ask Tony to fix this bug.
Example:
tooltip.rar [195.91 KiB]
Downloaded 439 times
PostPosted: November 6th, 2012, 3:37 am
Great!
I used the bindtooltipcontrol, but it's implies more work to do the "hint" "manually" :)
We wait the next version without this little bug.
Thanks Qiancang for your feedback! ;)
PostPosted: November 6th, 2012, 8:20 am
Tony said he was unable to fix this bug. :cry:
PostPosted: November 6th, 2012, 9:25 am
Ups... :cry:
Lets use "the bindtooltipControl" funtion then.
thanks anyway!
PostPosted: March 13th, 2013, 4:38 am
The best way to solve this problem is this:
function widgetOnLeave()
WindowZPosition=2;
function widgetOnEnter()
WindowZPosition=1;
PROBLEM SOLVED!!!
