PostPosted: October 2nd, 2012, 8:53 am
Hey Tony! when the position is set to "Keep topmost", you can not see the "tooltips" that are behind the widget automatically. Can you fix this?
Thank you very much!
And: Congratulations for the 1.73 version! It's so cooool!
Armando
PostPosted: October 2nd, 2012, 4:27 pm
I second this request... and the congratulations!!
PostPosted: October 18th, 2012, 12:12 pm
Tony: ¿there is some solution for this problem?
Thanks!
Users browsing this forum: No registered users and 214 guests
