Tony wrote:
Dagedee wrote:
Since using XWidget 1.7.3 I've got several times "access violation ..." I think it happens when I want to save the settings of a widget. (Win7 64 Bit)
The attachment access_violation.png is no longer available
Hi, Thanks for your feedback, can you tell me what is "save the settings "? thanks
Hi, "save the settings" means "save the widget" after making some adjustments, such as modifying the font or size or color or creating a new widget. Unfortunately there appeared another "access violation" in the meantime. Out of 10 times (saving the widget) it happend 4 times that one or both of the "access violation" alerts appeared and I had to close the program by using the task manager. And also at every mouse click at the desktop a new "access violation" alert appeared.
greetings
