PostPosted: September 29th, 2012, 11:38 am
Is it normal that widgets don't retain their setting when they are closed? As long as I keep them open or hidden they are fine even after boot but closing erases their settings. Just wondering if this is the way it is supposed to be.
PostPosted: September 29th, 2012, 10:44 pm
Hi, you can right click the widget and select menuitem [window]--[function]--[save as default config]
PostPosted: September 30th, 2012, 9:34 am
Thanks, that was what I needed. Nice program, but the menu's do take a bit of getting used to.
Users browsing this forum: No registered users and 214 guests
