 Post subject: XWidget V1.73 - tooltips
PostPosted: September 28th, 2012, 1:22 pm
XWidget V1.73
Add: Add Custom Tooltip style function. Support custom tooltip style for every widget in XWidgetDesigner
Improved: Display tooltip Even if widget not get Focus
Great improvements to Tooltips, thank you. :D
The default display time for the tooltip appears to be 3 seconds, can it be modified ?
Or added as a option to "custom tooltip" ?
Also an option to disable the time period so display of tootip remains while mouse in over.
PostPosted: September 29th, 2012, 10:43 pm
Thanks for your feedback, I will change the default display time for the tooltip to 60secs
PostPosted: September 29th, 2012, 11:18 pm
Thank you Tony
Default of 60 sec is OK :)
So I assume it is not possible for the user to adjust this setting ?
Thank again :D
PostPosted: September 30th, 2012, 1:11 am
OK,I will also add option for adjust this setting :)
PostPosted: September 30th, 2012, 3:13 am
Thank you very much :D
PostPosted: November 1st, 2013, 2:40 am
Hi Tony,
maybe a silly question, but where can I find that promised adjustment (expecting it somewhere in the Tooltip Builder)?
I'm talking about V1.88 (and I could not find it in V1.84 either).
My tooltips are still shown for only 5 seconds (and not for 60), and I'm badly missing that adjusting feature, at least the timeout=60s. (Can I set the timeout inside the code?)
With kind regards
