 Post subject: Component Style's
PostPosted: September 14th, 2012, 1:53 am
Each time i change one of my elements (text) and i have 10 more in the same layer, i would like them to look the same so i change each one of them one by one. So each time you want to change a small thing in a text / button etc... it take you lots of time to do so.
If you would had enough time Tony could you make a multiple selection of components or just create style each which each element could be be alloyed to with code or design. thanks! 8-)
p.s. If you don't have enough time or will, i could write it by myself you would allow me to help you.
 Post subject: Re: Component Style's
PostPosted: September 16th, 2012, 7:30 am
Hi, vlad, you can edit the main.xul file in the widgetFolder with notepad to change the element.
Please close XDesigner before you do so.
PostPosted: May 15th, 2013, 2:57 am
Pls share more info like this.
__________________________________________________
Diablo 3 Gold;WOW Gold;Diablo 3 Gold Kaufen;Guild Wars 2 Gold
Users browsing this forum: Bing [Bot] and 212 guests
