PostPosted: September 3rd, 2012, 10:07 pm
I have a monitor with full HD resoluiton. I want to create this widget with fit screen width. But there's the width limitation of chart object. I think limit is 1680px. Is this done for technical reason or will be removed on further version?
here's how it's looks like:
File comment: widget.Left = WorkAreaLeft;
widget.Width = WorkAreaWidth;
chartOut.Width = WorkAreaWidth;
chartOut.Left = 0;
chartIn.Width = WorkAreaWidth;
chartIn.Left = 0;
_____________________________________
chartOut.Left = -200;
chartIn.Left = -200;
______________________________________
chartOut.Width = WorkAreaWidth+200;
chartIn.Width = WorkAreaWidth+200;
PostPosted: September 4th, 2012, 2:59 am
Hi Shezoid ,
Thanks for your feedback, You are right, I will Change this limitation to 4000 in next version of XWidget.
In now version or xwidget,you can try to change the Chart property "SpaceWidth" to 2 or larger, then it will fill all the width
PostPosted: September 4th, 2012, 3:08 am
ok, thanks!
Users browsing this forum: No registered users and 214 guests
