 Post subject: Bugs with fonts.
PostPosted: August 9th, 2012, 1:14 am
When you use the same font in a few skins, there is a bug: Fonts look different. If you leave one skin, bug disappears. How do I fix this?
 Post subject: Re: Bugs with fonts.
PostPosted: August 12th, 2012, 5:29 am
Tony please.
PostPosted: August 14th, 2012, 5:21 am
Hi RaDMaN ,
Can you upload the left skin on your screenshot? I will try to find what is the wrong, thanks.
PostPosted: August 14th, 2012, 9:21 pm
Tony, It works fine when he is alone. And if a few skins with the same font, it looks like on screenshot. So it is with others, they also work fine if they are one with this font. And if a few skins with this font, they looks like differently.
Users browsing this forum: No registered users and 158 guests
