PostPosted: August 4th, 2012, 3:01 pm
The CpuCore does not return actual CPU usage, just zero.
PostPosted: August 26th, 2012, 6:15 pm
Could I get some kind of response as to the status of this bug?
PostPosted: August 29th, 2012, 7:11 am
It works perfectly for me, I don't know why doesn't it work for you. Though, what kind of processor do you have?
PostPosted: August 29th, 2012, 10:54 am
I have a single-core 2.1GHz Intel Celeron 900 CPU.
PostPosted: September 1st, 2012, 12:42 am
Hi,Do you installed the last version of XWidget?
PostPosted: September 1st, 2012, 12:36 pm
Yes.
EDIT:
The suggestion mentioned on the Chinese Skin Development forums, to run XWidget as an administrator, does not fix the problem.
Also, I'm running x64 Windows 7 Home Premium.
PostPosted: September 9th, 2012, 4:55 pm
There is a possibility that your processor is old and it does not support any kind of feedback. You should update your drivers and check the manufacturing date, if possible.
Users browsing this forum: No registered users and 214 guests
