Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 1 post ]
 Post subject: QUICK FAQ HELP
PostPosted: October 18th, 2017, 4:10 am
How to change the weather language:
1. Touch on the widget on the homescreen
2. Select "Weather Information" and open the Weather options (top right)
How to change the weather update interval:
How to change the date language from English to your phone's language:
All the widgets are made using the english language as default.
Edit the widget and change the corrisponding text's code-tag under Attributes->Bind Core->Core label.
1. Day
${WeekEn} -> ${Week}
${WeekEnShort} -> ${WeekShort}
2. Month
${MonthEn} -> ${MonthTxt}
${MonthEnShort} -> ${MonthTxtShort}
Exit and Save
How to remove the zero "0" from a digital clock:
${Time0} -> ${Time}
or
${Hour0} -> ${Hour}
Exit and Save
How to open an app touching the widget (whole area) or disable the popup windows:
2. Select "Settings and About" and "Open an App" or "None"
If you select "None" to enable the popup window you have to re-add the widget on the homescreen.
How to create a Hotspot (Normal Mode):
1. In the XWDesigner add a Hotspot component and move it where you want to apply the On-Touch function.
2. Assign the Binding Core and select the tag/function you want to use for the Hotspot from the OnClick tags list.
How to create a Hotspot (Advanced Mode) to assign a certain part of the widget to open a particular application (installed or stock of your phone):
1. Add ShortCutCore/s. (how many apps will be assigned and use at the same time touching on a certain part/s of the widget)
2. Add the Hotspot/s and move them where we will touch to open the app.
3. Assign to each Hotspot the corrisponding Binding Core / ShortcutCore and use the !Open tag.
Hotspot1: shortcutcore1 - !Open
4. Create the Right click options so you can Edit/Change the shortcuts/apps after the first assignment.
5. Add a MenuItem, edit its Caption writing for example Change Shortcut 1 and assign the corrisponding Binding Core and !ShowSetting as tag for the OnClick Event.
How install widgets on Android phones:
1. Make sure your PC XWidget is the latest version:
(You can download it from here: http://xwidget.com/)
2. Open the phone's system options "Settings - USB mode - Allow USB debugging".
3. Next connect your Android device via the USB cable plugged into the computer and install the Android USB driver.
4. Open the PC XWidget Editor. On the left down corner click on the on the green Android robot icon to detect the connection status.
5. Click on the "Android Mode" button on the top and then on "Send to phone" to send the widget to your device.
The new widget will be available in the app's Widgets list. Click on it to add the homescreen.
6. Each time you make any modifications at the Editor of the computer, you can directly click on the "Send to phone" button
and the widget on the phone will immediately and automatically refresh and display the latest changes in real time!
Users browsing this forum: No registered users and 13 guests
