PostPosted: September 10th, 2018, 10:05 am
There is no separate forum for XSprite so I ask my question here:
Is it possible to add/create my own animations for the nice Android XSprite app ?
PostPosted: September 10th, 2018, 11:23 am
Hello JuzerNeem. Yes of course you can! To create a sprite "widget" for XSprite you need only 3 files (2 .png images and 1 .ini)into a folder.
1. Default (preview image)
2. right (single png serial image)
3. ini file that includes the follow values:
FrameCount=22
interval=50
zoom=0.8
FrameCount is the number on the images of the "single png serial image"
Interval is the speed of the animation (bigger value -> lower speed)
Zoom is how appears the widget on phone's screen (size)
I attach a demo "widget" to see it from the inside. Keep in mind though that you need XWidget app to install/move the "XSprite widgets" to your phone since the sprites are created as "widgets"
Then you only need to move the sprite's folder to XSprite->Widgets folder
Happy Dog 3.zip [293.59 KiB]
Downloaded 1185 times
PostPosted: September 11th, 2018, 12:03 am
Ah, Great!
Is it also possible to have a non moving (but animated) sprite ?
(Disable the 'swim' behaviour ?)
PostPosted: September 11th, 2018, 3:14 am
You can have a simple/single png image as "sprite" but no the swim behaviour cannot be disabled. At least for now.
I will talk about it to the Dev to add it maybe in the next version.
Thanks
EDIT: And don't forget that you can share your sprites and they will added to the official gallery :)
PostPosted: November 7th, 2019, 3:49 pm
Thanks
Hi Jimking, could you please let me know the software and method you used to create the animated png file for the example "happydog" above?
Thanks,
Users browsing this forum: No registered users and 11 guests
