It is currently October 23rd, 2026, 2:37 am
PostPosted: September 25th, 2018, 1:04 pm
I modified the existing Transparent 4x1 and Transparent Clock Weather EX widgets just to make a few personal adjustments.
For 4x1, I increased the current temp font size and added real feel temp (green, below high and low). There are also hotspots:
    Over the weather image to go to the weather details,
    Over the current temp to refresh,
    Over the calendar to launch a shortcut, which I use to launch AccuWeather since I'm testing refresh frequencies.
For EX, I also increased the temp font size, got rid of a few weather details that I don't use, and added both refresh time and hotspots as above. The refresh time includes # minutes since last update for testing purposes.
Thanks.
transparent clock weather ex.xwp [2.49 MiB]
Downloaded 614 times
transparent 4x1 widget 2.xwp [2.07 MiB]
Downloaded 574 times
PostPosted: September 25th, 2018, 3:21 pm
Thanks for sharing! I will post them in the app's gallery as soon as possible :)
Users browsing this forum: No registered users and 54 guests
