 Post subject: HydrogenOS Clock Widget
PostPosted: October 11th, 2015, 5:28 pm
HydrogenOS Clock Widget for Xwidget
Change widget wallpapers,
17 original HydrogenOS wallpapers.
New files are smaller
RAR CONTENTS:
Two Versions:
A version for HD devices (7.87 MB)
a version with smaller images for no HD Devices. (4.50 MB)
Download>
HydrogenOS_Clock.rar [12.39 MiB]
Downloaded 1114 times
Deviantart Link
http://duophased.deviantart.com/art/HydrogenOS-Clock-Widget-for-Xwidget-565385567
PostPosted: October 12th, 2015, 4:00 am
Thanks for sharing :)
I think that there is something wrong in the HD version. Why the empty png "imag0" is 3,35Mb..?
I open it with GIMP, re-saved and it's only 5,33Kb!
Suggestion: Since the images are not with transparency, you can convert them from .png to .jpg to decrease more the size..
I tested and the HD version will be ~4Mb.
(the XWidget galleries require widgets <10mb)
PostPosted: October 12th, 2015, 11:10 am
:cry:
Ok, I will change the format to jpg. I will upload the new version with smaller size
PostPosted: October 12th, 2015, 2:32 pm
New files uploaded :D
Users browsing this forum: No registered users and 53 guests
