PostPosted: June 1st, 2015, 3:03 am
ZTE saga continues so here are three variants of the same widget. First one is close as original one, second widget is with blue back and third one is with changeable weather background.
Hope you'll like it.
See Ya...
zte_blade_wthback.xwp [10.3 MiB]
Downloaded 1166 times
zte_revisited_blue_back.xwp [5.2 MiB]
Downloaded 1103 times
zte_blade_resemblance.xwp [4.96 MiB]
Downloaded 1125 times
PostPosted: June 1st, 2015, 4:23 am
ALL are COOL! Thanks man! :D
You need to pay attention at the default image though.. It's different and appears with background white color.
And we need to re-create the background image with the same size. You simply resize it but appears all blur milicevic....
When I have some free time I'll recreate it with GIMP.
PostPosted: June 1st, 2015, 7:25 am
thanks for the suggestion. I've already made changes and uploaded new files.
PostPosted: June 1st, 2015, 5:18 pm
Give me time and I will optimize the background and the rest of the visuals..
They need some work...
PostPosted: June 2nd, 2015, 3:12 am
Suggestions:
1) Before or after you assign a tag/core to a text, DELETE the default text field "text1,2..." etc.
They appear when the widget is loading and this is not good..
2) Keep in mind that is always preferable work with quality images. Is better have a quality smaller widget than a large but blurry..
PostPosted: June 2nd, 2015, 5:20 am
Hi mate,
thanks for your suggestions.
Regarding text I thought that it should be there because of the program. If it is not necessary to be there, no problem to remove it.
Also for the image. As I told you before that I wanted to recreate the ZTE Blade weather widget, I noticed that the background of the original one is transparent, so I use the background of the clock widget I've already sent you, it looked very convenient in my effort to make everything closer look to original, as much as possible. That is why I use that stuff. No problem to find new one or make one. If I have original widget it will be much easier.
I am not that familiar with the program that much, this my first use, so I really appreciate any of your suggestions.
Thanks !!
PostPosted: June 2nd, 2015, 5:41 am
Don't worry, it's all about practice..! :)
I started to create my HQ versions from the scratch...and I will post them on DeviantArt as alternative versions.
PostPosted: June 2nd, 2015, 10:25 am
My alternative HQ versions are posted (PC VERSION) :D
All are re-created by me and from the scratch...
Please check in the "Share Your Creations" section:
viewforum.php?f=11
the ZTE Blade 3 digital clock.
PostPosted: June 2nd, 2015, 12:37 pm
It looks absolutely great. Nice work mate !!
PostPosted: June 10th, 2015, 6:35 am
thanks for theese i like them alot :)
Users browsing this forum: No registered users and 54 guests
