Post new topic Reply to topic  [ 17 posts ]
 Post subject: GALAXY S5 HD Weather
PostPosted: March 22nd, 2014, 9:12 am
Here it is my GALAXY S5 weather widget HD
Galaxy S5 DELUXE.rar [3.98 MiB]
Downloaded 4125 times
 Post subject: Re: GALAXY S5 HD Weather
PostPosted: March 22nd, 2014, 10:04 am
Thanks for sharing!
Please upload the .xwp file using the attach function, and it will be better take a screenshot of the widget on your desktop with a pic behind.
PostPosted: March 22nd, 2014, 10:19 am
file is too big 8 mb
here allowed 5mb
/how can i add this widget for all to download on android withe xwidget app
PostPosted: March 22nd, 2014, 10:34 am
here allowed 5mb
Have you tried to upload the file? I think that the limit is 10Mb now.
If you still have problem, you can compress the .xwp using winrar.
With .rar format the file size will be ~3-4Mb.
Only the staff of the XWidget team can post widgets in official pc/android gallery.
First upload the widget here as I told you so I can test it..
PostPosted: March 22nd, 2014, 10:45 am
first post edited
PostPosted: March 22nd, 2014, 11:03 am
Thank you @dack23. The widget have some problems though..
I'm testing it and I will tell u..
PostPosted: March 22nd, 2014, 11:11 am
but its working ^^ :D
i hope there are not many problems
PostPosted: March 22nd, 2014, 11:17 am
1) You didn't made this in your pc?
After dl the file and run it the widget is not saved in the widgets folder.
EACH WIDGET MUST BE CREATED ON THE PC FIRST and THEN port it for Android!
If not ,the Designer CAN'T move the widget on the Android.
XWidget is a pn program after all , so the widget must be worked properly on pc first.
Try to run the widget (after move manually the widget's folder in the right My Docs->XWidget folder) and you will see how it looks...
2) Missing the accuweather core for the background images/weather conditions
3) As I see you used my "Galaxy S4 Weather Clock HD" widget, modifying some things, but you need to fix these things to make it work properly..
4) At the end you don't have/use the fonts of the screenshot. So the txt visuals are different.
You need to assign a custom font to your texts.
(I moved the topic to the Android section)
PostPosted: March 22nd, 2014, 11:23 am
yes i modified ur s4 widget
on PC your s4 also dont have accuweather core when i edit in on pc
but when its on android there is accuweather core when i add on pc accuweather core i have on android 2 acuweather core
background images/weather conditions also work on android without any problems
look all working on android fonts images weather
PostPosted: March 22nd, 2014, 11:33 am
on PC your sr also dont have accuweather core
background images/weather conditions also work on android with any problems
Download it and you will see that THERE IS the accuweather core! :lol:
viewtopic.php?f=11&t=4235
I think you're confused a bit...MUST BE only one accuweather core.
Forgot all you did until now, and try to create the widget on PC from the beginning. The base of the widget is the same as the "Galaxy S4" widget so it will be easy and fast.
Sorry to tell you but your widget not work as it should.. :|
EACH WIDGET MUST BE CREATED ON THE PC FIRST and THEN move it for Android! This is the procedure.
PostPosted: March 22nd, 2014, 11:42 am
i try it uploading soon
PostPosted: March 22nd, 2014, 11:55 am
Take you time dack... If you need any help just tell me :)
PostPosted: March 22nd, 2014, 12:31 pm
can u test this
Galaxy_S5_Weather_HD_DELUXE.rar [3.96 MiB]
Downloaded 2172 times
PostPosted: March 22nd, 2014, 1:25 pm
dack23 wrote:
can u test this
On the pc works ok except that you copy the folder of my widget "galaxy s4 weather hd" and then you add a different name in the Designer (widget display name). So when I tried to install it, asked me to overwrite the previous one (my widget)
To have a full different/new widget, remember that you need also to rename the folder of the widget (my docs->XWidget->widgets-> "name of the widget") that should be the same with the name added in the designer. ;)
I made this changes:
Preview image -> delete
Default image - > change
Check...
Now on Android we need to fix the alignment of the texts.. Look:
The "Text Align" is important when we port a widget from pc to Android (I can do it for you)
The only thing that I think that clould be done, is to make some changes to make it more similar than the original GS5 widget.
If we leave it as now, is just a copy of my widget with only different images... So this one doesn't have his own style.. :|
I don't know if they are so similar though because I don't have a GS5 to see the original! :lol:
galaxy_s4_weather_hd.xwp [7.86 MiB]
Downloaded 1506 times
PostPosted: March 22nd, 2014, 1:40 pm
ok sounds good make port it to android
and the images are all from the new s5 akkuweather widget so it looks like the new s5 widget
here is the apk
http://ul.to/pg1k7sm4
and i forgot to add this refresh image
but for now i go to bed ^^
good night thx for help
PostPosted: March 22nd, 2014, 2:41 pm
You're welcome @dack23.
I'll try to fix all the missing parts..
PostPosted: March 22nd, 2014, 5:28 pm
Your widget work ok on pc but at the end I decided to re-create all the parts from the scratch using the default smaller images..
Here is my working version FOR ANDROID :)
For my pc version:
viewtopic.php?f=11&t=4276
galaxy_s5_weather_hd.xwp [6.11 MiB]
Downloaded 1484 times
Users browsing this forum: No registered users and 40 guests
