 Post subject: Ubuntu Clock-X1
PostPosted: February 1st, 2014, 2:56 am
Created new widget
Ubuntu Clock-X1.xwp [204.32 KiB]
Downloaded 793 times
 Post subject: Re: Ubuntu Clock-X1
PostPosted: February 2nd, 2014, 4:29 am
Please check it. Doesn't work properly.. Also use English language as default for the widgets.
The codes and the right click options are wrong..
ALL THE COMPONENTS AND RIGHT CLICK OPTIONS THAT ARE SAME FOR PC AND ANDROID VERSION (EXCEPT THE HOTSPOT) SHOULD WORK ON BOTH PLATFORMS.
IF THIS IS NOT HAPPENING SOMETHING IS WRONG.
