Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: HTC Sense 4.0 Red-X1
PostPosted: January 30th, 2014, 2:38 am
Created new widget.
HTC Sense 4.0 Red-X1.xwp [414.24 KiB]
Downloaded 830 times
 Post subject: Re: HTC Sense 4.0 Red-X1
PostPosted: February 2nd, 2014, 4:29 am
Please check it. Doesn't work properly.. Also use English language as default for the widgets.
The codes and the right click options are wrong..
PostPosted: February 2nd, 2014, 6:01 am
And if you look? on the screen shows that it works!
PostPosted: February 2nd, 2014, 6:10 am
Man as I said I CHECKED and EDITED your widgets LIVE and don't work properly. I saw from the inside that there are WRONG and EMPTY CODES.Not works even on pc how work on Android??? :shock:
If you try to install any of your widgets on pc to test it, you will notice that they're not even saved in the right path
My Docs-XWidget-Widgets
ALL THE COMPONENTS AND RIGHT CLICK OPTIONS THAT ARE SAME FOR PC AND ANDROID VERSION (EXCEPT THE HOTSPOT) SHOULD WORK ON BOTH PLATFORMS.
IF THIS IS NOT HAPPENING SOMETHING IS WRONG.
Users browsing this forum: No registered users and 53 guests
