 Post subject: Download skins question
PostPosted: August 24th, 2017, 11:08 am
I can no longer download skins thru the site. I am registered in the forums and have paid for a membership, but I don't have a membership number yet. What do I do in the interim so I can load skins again? Thanks. John Burns
PostPosted: August 24th, 2017, 1:28 pm
Hello JohnBurns. Just to know, which kind of payment you have chosen?
After that you will receive automatically an email with the code to use.
1) Download the latest version of XW
2) Press "Update to pro"
3) Fill the fields with your personal email and code and restart XW
4) Then you can have access to all the widgets through the online gallery (click on the "More Widgets..."
from the icon tray)
The old widgets that you had installed they will work equallly. You can still find many free external widgets from here or DeviantArt
PostPosted: September 14th, 2017, 4:47 pm
JohnBurns had Download the latest version of XWidget and solved this problem
Users browsing this forum: No registered users and 51 guests
