 Post subject: XWidget Designer...
PostPosted: January 19th, 2020, 8:32 am
Hello,
Is there a tutorial or help files available so I can learn how to use the XWidget Designer program? I figured out how to do some very, very basic things (kind of) but I'm miles off of actually creating a quality XWidget myself, and I really want to create a few custom widgets for myself and for the community.
Thanks,
-grayswandir.
I have been, and always will be, your friend.
 Post subject: Re: XWidget Designer...
PostPosted: January 19th, 2020, 10:28 am
I suggest you to check these sections
viewforum.php?f=10
viewforum.php?f=8
and
viewforum.php?f=8
Especially in the first two you'll find many things and answers that will help you to understand how it works.
Personally at the beginning I used other ready widgets to check them from the "inside" and see how the things work. Now if you have java script knowledge, it helps a lot to create more complicated widgets. But don't worry. I started from zero and with practice I learn many things :)
If you need any help about designing or creating widgets feel free to ask...
PostPosted: January 19th, 2020, 2:29 pm
Hey Jim,
Thanks, I didn't realize that's how you started out. Most of the content in XWidget was created by you, so that's pretty impressive. I appreciate the links, I'll get to it so I can learn how to make some basic widgets.
-grayswandir.
