PostPosted: January 18th, 2020, 5:47 am
Like the title says, I want to change a font in an XWidget, but the font is not a .ttf (true type font) it's an .otf (open type font). For whatever reason, XWidget Designer doesn't recognize the .otf file format for fonts.
Is there a way around this small problem?
Thank you,
-grayswandir.
I have been, and always will be, your friend.
Removed the size command
PostPosted: January 18th, 2020, 6:01 am
Hello grayswandir. XW's designer supports only fonts in .ttf format.
You can use any online font converter. I use these two sites:
https://onlinefontconverter.com/
https://everythingfonts.com/otf-to-ttf
(the first is the best better because as I notice all this time, converts any font even the ones with "protection")
PostPosted: January 18th, 2020, 10:13 am
Hey Jim,
Thank you very much, that was exactly what I was looking for!
PostPosted: January 18th, 2020, 12:07 pm
You're welcome :)
