It is currently June 13th, 2025, 3:43 am
Post new topic Reply to topic  [ 15 posts ]
 Post subject: Samsung Note 9
PostPosted: June 6th, 2019, 3:31 am
Hi
i using the Xwidget pro app and beside my best widget by slavoo, on Samsung Note 9. The widget is constantly crash on every 3-5 hour. I use nova launcher, and my phone is on android 9. I set the phone so the applicaton not go to sleep, but it happens anyway. What should i do ?
 Post subject: Re: Samsung Note 9
PostPosted: June 6th, 2019, 8:20 am
Wait for update. Tony [developer] checking this problem. It does not work on my phone either. Android 9
PostPosted: June 7th, 2019, 12:26 am
Hello ace05hun. Thanks for your report.
The app has been tested to Android 9.0 too. In any case Tony, is out home these days for some important personal matters , so he'll re-check it asap.
Thank you
Edit: Android 9.0 has more agressive battery saver options. You need to be sure that the app is NOT in the battery save apps list same as system's guard/ram auto-optimization list. The fact that the widgets stop work after an amount of time shows that the app is blocked/stopped by the OS to save battery when the phone goes to deep sleep or during standby.
PostPosted: June 10th, 2019, 4:08 am
Hí!
I also put the application to the " the systém not check how much memory the application use " list, but its still happening. So whats ny next option ?
PostPosted: June 10th, 2019, 9:15 am
Thank you
In my phone, XWidget has turned off the battery optimization
In the section of closing the application [task killer] XWidget is blocked, so it is not closed.
According to the settings, nothing blocks it from the available options on Android
Despite the proper settings, widgets after some time are blocking the same as the entire XWidget
As I wrote, version 1.94 works correctly on Android 9 so it is not the fault of Android 9 only XWidget application. It's logical!
The only mistake in version 1.94 is "flash 1.jpg during weather update"
PostPosted: June 10th, 2019, 11:25 am
I see. Tony's phone has Android 9.0 and works fine. Strange.. I personally don't have any of these issues because I have Android 7 on my phone.
In any case when Tony turns back he will continue the development.
PostPosted: June 15th, 2019, 4:48 am
I downgraded to v1.94 and that solved my problem
PostPosted: June 15th, 2019, 6:45 am
Yes, this is the best solution for now. The app passed from Eclipse to Android Studio and to the latest sdk and as it seems the transition brought some problems to Android 9. On my phone with 7.0 the 1.97 version works fine. Tony will try to resolve the issues asap returns home and continue the development.
Thank you
PostPosted: September 14th, 2019, 9:48 am
So is there any news ?
PostPosted: September 14th, 2019, 2:34 pm
Tony will update the app asap trying to fix the bugs reported .
PostPosted: December 11th, 2019, 3:18 pm
Ok, at this point, i think i don't think the isues are gonna get fixed. It was a good app. Shame......
PostPosted: December 12th, 2019, 4:08 am
ace05hun the app is not abandoned! Be sure of that. The problem is there is no team behind the development. All the apps come from a single person- Tony. The last period Tony has to deal with some serious problems in his real life that don't leave too much space from the further development and bug fixing. I can't tell you more because it's something really personal from his life..
I'm in contact with him and he knows about the issues. Unfortunately all started from the force-update of the SDK and Android Studio platform from Google. Changing the programming language the issues came out. He told me that he will continue the development/bug fixing asap. We're sorry for the trouble, but as you know real life comes first...
PostPosted: July 24th, 2021, 1:55 pm
Any update?
PostPosted: July 25th, 2021, 2:47 am
ace05hun wrote:
Any update?
No ace05hun. The developer turned XWidget for PC and Android to all free. Now, I don't think that there will be an update soon.. At least for Android..
PostPosted: August 31st, 2021, 10:41 pm
It's good that the forum is finally up and running
Users browsing this forum: No registered users and 3 guests
