PostPosted: August 6th, 2017, 6:59 am
XWidget [v1.3.2] in Google Play ready to download. Please update. [12/08/2017]
XWidget: https://play.google.com/store/apps/deta ... dget&hl=pl
XWidget PRO: https://play.google.com/store/apps/deta ... _pro&hl=pl
CHANGE LOG:
Add CPU Core. Add Tags of CPUName , CPUSpeed , Percent
Remove the notification bar icon of XWidget
Fix the weather forecast refresh delay problem
Imporve weather data update
Fixed the clock/weather stop update problem finally
Add a hint to guide you how to hide the notification icon (long press the notification icon and uncheck the option "Show notifactions")
Fixed some small bugs,Improve stability
PostPosted: November 11th, 2017, 5:00 am
v1.3.4 in Google Play
