PostPosted: June 13th, 2017, 5:08 pm
Peace...
I've followed every tutorial -- even downloaded XDesigner and I am still baffled as to how to assign an app to my one of my hotspots on XWidget. Is there any way to assign a hotspot natively through the Android app without having to go through the PC? Totally lost..please help
PostPosted: June 14th, 2017, 12:23 am
Hello ZDK. As I understand from your request you will need to follow this tutorial:
How connect your phone:
viewtopic.php?f=23&t=3776
How create a hotspot/assign an app:
viewtopic.php?f=23&t=5320
Yes you can create a hotspot even from your Android device. I personally use the pc XDesigner because I think that it's faster and it takes 5 mins..
I personally wrote the tutorials as simple as possible. Please try and tell me where you have problem and I'll assist you..
On your phone
From the home screen touch on the widget and select 'Edit'.
This is the XDesigner that works with the same logic as on pc.
1)Go to 'Other' tab, and press the 'Hotspots' and '+' to create it.
2)Add a name of the function you want or any name.
You will see a colourful square that appears on the designer there. Move it and resize it according where you want to be the touch area on the widget.
3)Then go to 'Attributes' tab and select the 'Core' and the 'Click Event'
To create a 'right click' style option so you will can edit the shortcut later directly:
1)On 'Others' tab, select 'Cores', '+' and add a 'shortcutcore'.
2)Go to 'Others', 'Menu Items', press '+'. Add a name that will appear in the options list touching on the widget.
3)Then go again to 'Attributes', select the Core - shortcut and Click Event the '!ShowSetting'
4)EXIT and Save
I will add an extra tutorial in that section about how to create a hotspot directly from the phone.
