It is currently October 23rd, 2026, 2:37 am
PostPosted: December 29th, 2015, 2:39 pm
Hi. After some hours of inactivity widget is hanging. Clock stops and I need to tap on it to update. Issue reproducing on several miui versions including last
I'd posted bug report to miui, but they said it's not miui problem.
en.miui.com/forum.php?mod=viewthread&tid=201545&extra=page%3D1
PostPosted: December 29th, 2015, 8:18 pm
Topic moved to the right section.
Unfortunately some roms still have this bug.. Yes,it's not miui problem. The dev will try to fix it for the next version.
PostPosted: February 25th, 2016, 10:42 pm
In my opinion, the phone comes into DEEP SLEEP This Widget does not work in the background. So much for my observations.
Users browsing this forum: No registered users and 43 guests
