PostPosted: September 17th, 2015, 1:01 am
Tony please update the XWDesigner of the pc version to match it with the new features/components to use of the last version of the app v1.0.9. :!:
You must add the new components in the pc designer because we can't upload widgets in the gallery that use these new components!
If the pc gallery doesn't support them how we can edit and test old widgets before post them in the gallery..?!
PostPosted: September 18th, 2015, 12:34 am
Hi Jimking,
Sorry I am on a business trip for work, I need get the source code in my home and edit to update when I go back next month :(
Tony
PostPosted: September 18th, 2015, 1:10 am
Ok Tony.. We will wait for you. It's a very important matter.
Thanks!
