It is currently October 23rd, 2026, 1:07 am
PostPosted: December 4th, 2014, 7:25 am
This is a really bizarre issue and one that is starting to frustrate me as I can't for the life of me work out what's going on!
At night I turn off my wifi and mobile data as I don't want any notifications from various apps throughout the night. The weather widget I'm using says, for example, "Clear night, 3 degrees".
When I wake up in the morning I look at my phone to turn on the wifi and before I have done, I see that the weather app has updated as it says, example, "Cloudy, 5 degrees".
I turn on my wifi and update the weather and it is the correct weather.
How can this widget update without any network connection? I don't know enough about android to try and problem solve this issue so any ideas would be great!
TIA
(btw, apart from this issue, really love xwidget!)
PostPosted: December 4th, 2014, 8:32 am
Thank you for your comment.
But how a function like the current weather that works and updates ONLY with an internet connection
wifi or gps/internet data can work without it?!
There is NO weather widget on Android or pc that works without internet, with one way or another! :!:
It's not like a clock or a battery widget that works using the phone/system's data.
PostPosted: July 8th, 2015, 10:36 pm
Thanks for this feedback. Great pleasure
Users browsing this forum: No registered users and 30 guests
