 Post subject: shortcuts and calendar
PostPosted: December 1st, 2014, 2:46 am
Is there a way to open shortcuts through hotpots?
Could we show calendar entries with text to widget somehow?
Thank you and sorry for my English.
PostPosted: December 1st, 2014, 4:33 pm
Please check this new section will the Tutorials:
viewforum.php?f=23
Now about calendar, if you mean use a calendar widget like this one:
http://jimking.deviantart.com/art/LG-Op ... -485832304
is not supported yet on Android...
PostPosted: December 2nd, 2014, 3:54 am
I need to edit widget from phone.My laptop motherboard died.Is there a way to do it?
As for calendar, i mean to show in widget my next appointment in example.
PostPosted: December 2nd, 2014, 9:58 am
As I told you check the Tutorial section. I wrote 3 kind of tutorial about the Hotspot function.
The procedure is the same. Only the position of the menus is different. I think it will be more easy to do it on a pc, but this is my personal opinion. You need to you understand how the things work as for every new thing.
Maybe you mean something about "Memo" XWidget widgets.
This function is not supported yet on Android. But for you can assign the note stock or any similar custom app using the hotspot
viewtopic.php?f=23&t=5320
