 Post subject: Need FIX
PostPosted: October 9th, 2014, 4:09 am
Here some things that I notice that should be fixed in the next version of XW.
1) The progressbar is not fully supported. Even with no back color, on Android show as black and the thumb option/image doesn't work.
2) Using txt and the battery status tag, it shows the opposite status Offline/Online.
3) The bold for txt doesn't work. Tony he told me that not all fonts support this on Android, but the fact is NONE of the fonts shows up bold. To work properly the imported .ttf must be bold on its own..
Also the "Interception" and "TextFrame" options should be activated.
Users browsing this forum: No registered users and 43 guests
