 Post subject: battery status tag
PostPosted: August 31st, 2014, 1:13 am
I notice that the battery status tag "${Status}" shows the opposite condition when applied..
When the phone is plugged shows "online" instead of "offline"..
Is there a way to fix this through a mod tag until the next version of XW...?
Edit:
I found another way, taking two screenshots of the text on both status and I used the battery status tag for android:
...my question is still valid though...
 Post subject: Re: battery status tag
PostPosted: August 31st, 2014, 3:20 am
jimking wrote:
Edit:
you can use [Substitute] to change the text, no need to use png
you should do these:
1. use a text object with ${isCharging} tag
2. in the Substitute box of text object use this:
true:Offline,false:Online,
edit:
i don't know if [Substitute] works for android version, Since i don't have android
PostPosted: August 31st, 2014, 5:10 am
Yes, I don't know if this option works on Android, since a LOT of options, even for the supported tags are still not available..
Thanks for your reply though! :)
