PostPosted: August 3rd, 2014, 4:25 am
Samsung Galaxy S4
I am having an issue with the weather not updating. My current location is now being found via gps; but the temperature/weather are not updating to the correct location. I have restarted the app and my phone and this has not helped. I checked the AccuWeather app..and all is good and correct.
I keep coming back to XWidget hoping the issues have been fixed; only to find that this issue stays the same.
Are you able to help me so I can use this app? If the weather is incorrect, there really is not point in using it.
PostPosted: August 3rd, 2014, 5:15 am
Go to option and select interval of update. For example, every 15 minutes. Check this.
PostPosted: August 16th, 2014, 1:19 am
The autolocation doesn't work properly (the dev is working on this). So is better to use wifi to find manually your location and update the weather.
Then will work without any issue. As Slavoo told you you can also select the interval of the update though settings.
PostPosted: October 1st, 2014, 8:12 pm
yes, i agree with jimking, i am also facing the same problem!!!
anamta
PostPosted: October 2nd, 2014, 1:32 am
On the last version the issue is resolved..
Also: This is the section for XWidget for pc NOT for Android!
Topic moved
