PostPosted: March 7th, 2014, 9:07 am
Good day!
I'm hoping I could get an assistance with regards to the Android mode/ support for XWidget. Is the Android version of Xwidget able to support/ show animated GIFs? If possible, is there a way to trigger the animation through an event (like facebook notification or when you touch the widget)?
PostPosted: March 8th, 2014, 6:10 am
anahkha wrote:
Good day!
No the Android version doesn't support gifs, and I think that it will be like this, to avoid high memory and battery consumption..
PostPosted: March 10th, 2014, 11:32 am
Thanks! I was looking for a means to animate some frames (nothing too fancy), but I guess it's for the best to keep 'em static for now.
