 Post subject: Help me
PostPosted: January 14th, 2014, 10:57 am
Hi
I want to create this calendar widget HTC Sense for XWidget. Is it possible? :idea:
 Post subject: Re: Help me
PostPosted: January 15th, 2014, 9:04 am
izmiryooo cal core is not supported YET!..
PostPosted: January 15th, 2014, 4:20 pm
if you need it on PC, you can make it using DateTimeCore and some Scripting.
but it need some time to be done.
PostPosted: January 16th, 2014, 4:45 am
Similar widget by Snorages: ;)
http://www.deviantart.com/art/HTC-old-c ... -334101806
PostPosted: February 1st, 2014, 3:21 am
PostPosted: February 1st, 2014, 11:58 am
izmiryooo wrote:
The developer Tony already works on this..! ;)
