It is currently October 23rd, 2026, 1:10 am
 Post subject: Forum dates strange
PostPosted: April 24th, 2015, 4:06 pm
I noticed that the posts dates contain Japanese symbols in them, went to my user control panel and took them out in the date format.
May be worth looking at.
Cheers, Pete
 Post subject: Re: Forum dates strange
PostPosted: April 25th, 2015, 6:34 am
Tony and who created the forum is Chinese! Maybe that's why..! :lol:
You can edit this from the "User Control Panel"->"Board preferences"
PostPosted: April 26th, 2015, 5:02 am
yes that was already set right.
I actually had to remove the chinese symbols to fix date in this area manually."My date format:"
Anyway it may help others who think it's a bit strange, that there is a work around.
Cheers, Pete
PostPosted: July 25th, 2015, 10:03 pm
My dates bcome correct once I login.
PS: the symbols are chinese!
