 Post subject: Forum search not good
PostPosted: April 24th, 2015, 2:02 am
It would be great if the search feature worked in this forum.
Unless I'm doing something wrong, I get zero results or message not enough characters.
Just does not seem right. I think it needs looking at.
Thanks
Cheers, Pete
PostPosted: April 24th, 2015, 8:35 am
Yes, sometimes happens and I can confirm that the search engine needs work.. In any case try to add more than one or two words.
PostPosted: April 24th, 2015, 7:13 pm
I did try that but it's still very awkward. There should be a setting for this in the Forum Admin.
Makes it very tough when you have to physically search for things.
Cheers, Pete
PostPosted: April 26th, 2015, 2:33 am
I don't but unfortunately I don't have admin privileges and maybe the knowledge to edit this part..
Users browsing this forum: No registered users and 21 guests
