PostPosted: February 16th, 2014, 12:20 pm
i want to start Programming and i don't know where to start:
my first learned Programming Language was Pascal that have a hard Syntax (ex: [:=] , [Begin,End] , ...)
and then i learned C++ and that is so easier than Pascal
and i have tried to start learning Visual Studio 2008 as a gui based one but i didn't like it's interface so i didn't continue on it; in fact i found all microsoft programs are hard to use for me and they are getting complicated in the any newer versions
so my questions are these:
1. first of all i want to know which Programming Language xwidget is using in Script Editor because it's easy to learn and use, and have easy syntax;
2. and if possible tell me which Programming Languages are having same Syntax as that
3. also if you recommend any other Programming Languages with better syntax tell me about that
4. did you recommend any gui version for these?
PostPosted: February 17th, 2014, 12:53 am
xwidget is programmed in delphi
javascript is used in script editor
PostPosted: April 10th, 2014, 12:12 am
All C families...
I started with Java, then went to c++, then C#, then to Assembly, now for maintenance works... had to go into VB
Users browsing this forum: No registered users and 16 guests
