It is currently October 23rd, 2026, 1:56 am
PostPosted: April 2nd, 2020, 7:20 am
// --- SHORTCUT AND MEDIA PLAYER --- \\
--- DESCRIPTIONS
- Change the text color of the buttons
- Change the color of the button hover effect
- Change the color of the "TextFrame" effect of the buttons
- Possibility to activate or not the "TextFrame" effect of the buttons
- Change the color of the "Shadow" effect of the buttons
- Possibility of activating or not the "Shadow" effect of the buttons
- Change the color of the button "Glow" effect
- Possibility of activating or not the "Glow" effect of the buttons
- Possibility to activate or not the Shadow effect of the Spectrum
- Possibility of activating or not the Spectrum Top Block
- Possibility of activating or not the animation of the buttons
- Possibility to activate or not the animation of the buttons of the media player
- Saving the position of the widget
- Add "ShowHideIconDesktop" button
- Add indicator media player "IsPlaying"
- Volume bar
--- USE
To use the shortcuts, simply drag and drop, otherwise by right clicking on the chosen button and "Edit Shortcut"
Same thing for the media player, right click and "Media Player Settings".
Many thanks to JimKing for helping, advising and testing the widget :)
If you need help, or notice a bug thought of me mp
or in this topic :)
Hoping you like it :)
ShortCut_And_MediaPlayer.xwp [255.51 KiB]
Downloaded 2238 times
// ===== Contact ===== //
https://discord.gg/9vyhv3F
// ===== My Widget ===== //
Users browsing this forum: Bing [Bot] and 120 guests
