It is currently October 23rd, 2026, 1:57 am
 Post subject: Calendar DatMatrix Dock
PostPosted: October 28th, 2018, 8:42 am
New created version dated 2018/11/01!
Updated to colourful version dated 2018/11/18
Just an other version of a calendar xwidget including over 30 shortcuts, also system information and utilities
Gerald Dat Matrix manual Bedienungsanleitung 10_2018.jpg [ 276.67 KiB | Viewed 57089 times ]
Changes:
- day isn't underlined but visible with a red point
- Shortcuts (and information about your shortcut) are visible in the menu if you use the lower area of the button (Cursor changes its shape)
I'm sorry but there was an error in the first version with the day 31 which wasn't shown underlined...
Feel free to download and use the file caldatmat.xwp or the new file caldatmatcolour.xwp
Notes:
-If information to the shortcuts isn't shown give Xwidget the focus with a mouseclick into the widget... (some more xwidgets need this...)
-If you see a window that reports about a problem of Java Script it's a problem with third Party software!
.Recommendation: restart xwidget, not only the widget!
Kind regards,
Gerald 2018
caldatmatcolour.xwp [2.49 MiB]
Downloaded 2194 times
caldatmat.xwp [394.11 KiB]
Downloaded 2091 times
Users browsing this forum: Bing [Bot] and 105 guests
