PostPosted: April 18th, 2018, 5:11 am
Revion Commander (the only non-limited shortcut widget)
Hi guys! I would like to present you Revion Commander. :)
It's the only shortcut widget which allows you to add unlimited number of shortcuts.
Add your own custom commands by editing of 'commands.ini' (it's really really easy) located inside widgets folder and then just enter your command in the textbox!
:idea: Type 'help' for help. :idea:
Example command:
[about]
action=answer
value=Created by DEVICARUS.eu, website developer. Right click this widget and choose 'Developers website' to open my website.
And why "Revion"? Because it sounds cool... and my Twitter is @RevionReaper. :D Actually when I don't know how to name something, I call it Revion. :D
Note: The logo was probably the hardest part of this to make, lol.
Planned features:
  • Command editor
  • Option to run multiple programs by a single command :twisted:
  • Make it not case-sensitive
File comment: v1.0.0, enjoy!
revion_commander.xwp [45.5 KiB]
Downloaded 1392 times
PostPosted: April 18th, 2018, 3:16 pm
Cool! 8-)
Thanks for sharing! Widget uploaded too
PostPosted: April 19th, 2018, 5:46 am
Jimking wrote:
Cool! 8-)
Awesome! I'm glad you like my widgets. :)
Users browsing this forum: Bing [Bot] and 124 guests
