PostPosted: December 30th, 2017, 12:34 am
Ahoj Všem. Omluvte prosím mojí angličtinu. Jsem z Čech. XWidget používám několik let. Můj poslední výtvor je miniaplikace: Nezapomeňte na váš lék.
https://www.youtube.com/watch?v=lp5fQDQ751w
Google translator :-)
Hello to everybody. Excuse my English please. I am from the Czech Republic. I've been using XWidget for several years. My latest creation is a gadget: Do not forget your medicine.
nezapomennaleky.xwp [2.96 MiB]
Downloaded 1728 times
PostPosted: December 30th, 2017, 1:24 am
Great! Thanks for sharing :)
PostPosted: December 30th, 2017, 1:44 am
Thank you ;)
PostPosted: December 30th, 2017, 4:16 am
You can also post it in the XWidget's Page on DeviantArt so more people can see and download your widget/s
We'll be glad if you share more of your works..
Thank you and Happy Holidays :)
EDIT:
I checked your widget through YouTube. Cool idea.
But please use english language for your designs and most of all english words for the image's names that you use. The Czech language like other languages for example chinese, polish, greek, russian has some "special letters" that are not recognised from the program.
XWidget supports ~40 languages but the elements used for the design should have latin characters
So practically the images are not appeared. Your widgets will work fine in your pc and for who uses Czech language but for NOT for all the rest..
Check for example your widget running on my pc:
That's why if you notice all the widgets are created in english. Then there is a way for each user to translate the widget if needed.
PostPosted: December 30th, 2017, 5:13 am
EDIT:
OK, edit: perhaps OK :D ;)
takemedicine.xwp [2.97 MiB]
Downloaded 1591 times
PostPosted: December 30th, 2017, 11:59 am
I will check it later tonight and reply....
PostPosted: December 30th, 2017, 12:25 pm
The images appear fine now! Thanks :)
Could you pls put some instructions in the original post about how the widget works, how the slidepanel moves, what we need to click etc.
This will be very helpful for who will want to use it....
Regards
Users browsing this forum: Bing [Bot] and 124 guests
