PostPosted: March 30th, 2017, 10:23 am
The widgets from the Samsung Galaxy S8 (clock, weather, 4x1 style)
Clock:
Weather:
- Change Location (or use the gps button)
4x1:
* THIS IS THE PC VERSION. TO USE THEM FOR ANDROID PLEASE DOWNLOAD FROM THE APP'S ONLINE GALLERY *
4/4/2017
- 4X1 style added
- The weather icons are now the original ones!
Galaxy S8 Widgets.zip [1.02 MiB]
Downloaded 617 times
PostPosted: March 31st, 2017, 11:58 pm
Hey, thanks for an excellent widgets!
There's a bug, however: weather icon not shown, when conditions are night-partly cloudy, it just shows empty space. Noticed yesterday, checked today with the different locations, definitely can confirm.
Thanks!
Edit: talking about android widgets here.
PostPosted: April 1st, 2017, 12:26 am
Thank you very much for the report! I fixed it.
Was a stupid error to the icon's number. Instead of 35 it was named as 35a :)
(I re-upload the widget to the app's gallery too. It needs some minutes to overwrite the original one)
PostPosted: April 1st, 2017, 12:36 am
Thanks so much, that was one speedy fix :)
PostPosted: April 1st, 2017, 12:44 am
You're welcome :)
PostPosted: April 2nd, 2017, 9:58 am
Also, official S8 weather widget has leaked (on s8 xda forum). In case you wanted to grab the icons :)
PostPosted: April 2nd, 2017, 12:11 pm
Ok thanks! :)
I also want to create the 4x1 widget. Could you please provide me a screenshot with that...?
PostPosted: April 3rd, 2017, 8:00 am
Sure, here you go!
PostPosted: April 3rd, 2017, 8:04 am
With negative temp
PostPosted: April 3rd, 2017, 11:01 am
Thanks! This will help me a lot :D
I create this kind of the widgets with a screenshot on the background to be exactly as the original one
I'm analysing the apks from XDA to find the pngs / icons
PostPosted: April 3rd, 2017, 1:05 pm
Nothing but respect for your work man!. Love new weather widgets from Samsung, but hate touchwiz, so you're the saviour:)
PostPosted: April 3rd, 2017, 2:58 pm
All ready! Enjoy :)
4/4/2017
- 4X1 style added
Users browsing this forum: No registered users and 188 guests
