 Post subject: Monochrome Desktop
PostPosted: July 27th, 2016, 11:16 pm
i try to make a widget full screen and can run in different Screen Resolution, and this widget still in development . . . :D
i hope XWidget Developer add new command or status on next update
- ShortcutListCore can delete multiple items.
- NetMonitorCore can check internet availability like "Online" or "Offline"
Support on Screen Resolution :
- 1024x768 = Max 77 Desktop Icons
- 1280x720 = Max 84 Desktop Icons
- 1280x800 = Max 98 Desktop Icons
- 1280x1024 = Max 126 Desktop Icons
- 1360x768 = Max 105 Desktop Icons
- 1366x768 = Max 105 Desktop Icons
- 1440x900 = Max 128 Desktop Icons
- 1600x900 = Max 136 Desktop Icons
- 1600x1200 = Max 170 Desktop Icons
- 1680x1050 = Max 162 Desktop Icons
- 1920x1080 = Max 180 Desktop Icons
- 1920x1200 = Max 200 Desktop Icons
- 2560x1440 = Max 300 Desktop Icons
Right click for PopupMenu =
- View
- Horizontal Desktop Position
- Vertical Desktop Position
- Show Desktop Icons
- Hide Desktop Icons
- Show Widget Panel
- Hide Widget Panel
- Desktop Icons Setting
- Enable Text Shadow
- Disable Text Shadow
- Change Text Color
- Change Text Shadow Color
- Change Text Background Color
- Delete All Shortcut
- Show Setting
- Show Net Log
- Screen Resolution
- Task Manager
- Control Panel
[ Keyboard Shortcut Button ]
when mouse cursor entering this widget you can press keyboard button =
- SHIFT + ESC = Show Shutdown Menu.
- V + M = Mute / Speak Volume.
- V + UpArrow = Increase the Volume by 10%.
- V + DownArrow = Reduce the Volume by 10%.
when mouse cursor entering desktop icons =
- F1 = Open folder selected desktop icons.
- F2 = Rename, Change Icon selected desktop icons.
- DELETE = Delete selected desktop icons.
- hold CTRL = to mark multiple desktop icons, then press DELETE to delete multiple items that have been marked.
[ Note ]
- if you turn on <Wallpaper Effect> may cause this widget run slow 8-)
- have autosave feature [ when xwidget on exit / suddenly exit then start xwidget again, will load last configuration ].
- let me know if you find an error/bug and i will try to fix and update again . . . :D
Monochrome Desktop V1.1.5.rar [8.97 MiB]
Downloaded 535 times
My deviantart = http://adiim.deviantart.com
 Post subject: Re: Monochrome Desktop
PostPosted: July 28th, 2016, 12:06 am
Thanks for sharing! :)
Very cool job 8-)
This is supported already. Similar function used here:
http://jimking.deviantart.com/art/White ... -345167428
PostPosted: July 28th, 2016, 12:10 am
PM: I will move the topic in the right section.
This is for pc not for Android. Please next time post your work here:
viewforum.php?f=11
PostPosted: July 28th, 2016, 12:21 am
Thanks Jim . . . :D
aw i think im share in PC version . . . :roll:
Users browsing this forum: Google [Bot] and 156 guests
