It is currently June 14th, 2025, 7:43 pm
PostPosted: June 2nd, 2016, 11:34 am
Android Mod version of the "Steampunk Orrery and Clock" Yahoo widget by yereverluvinuncleber.
http://yereverluvinuncleber.deviantart. ... -357064532
PERMISSION ASKED AND OBTAINED from the original designer.
What's new:
- The seconds hand shows the battery %
- Imported font
- Added weather icons, moved to the center for better look on Android
- Added temperature over the moon icon
- Added right click options
- Added Hotspots (x2)
Tap on:
- The Analog clock to set/open the Alarm/Clock app
- The weather icon to open directly the Weather Details screen
- Edit the shortcut(clock)
Since the original one is much more complicated, uses some cool functions and javascript and was created exclusively for pc,
I think that for the pc users is better use the original one. :)
I only made some minor changes. All credits go to the original designer yereverluvinuncleber.
TO DOWNLOAD AND USE THIS ANDROID VERSION PLEASE INSTALL THE XWIDGET APPLICATION:
https://play.google.com/store/apps/deta ... ft.xwidget
THE WIDGET IS UPLOADED TO THE APP'S ONLINE GALLERY.
Users browsing this forum: Bing [Bot] and 38 guests
