It is currently June 14th, 2025, 9:34 am
PostPosted: April 20th, 2016, 4:37 pm
The widget will appear as an arrow (windows 8/10 style) on the down-right part of your desktop.
* Use it to open the full screen weather window
* Use the buttons to swith between the 5-days forecast and the 5-locations current weather screen
* Use the "Details/Settings" to open the current's location weather details.
* Press "Exit" to close it and minimize the widget.
ON THE MULTI-LOCATIONS screen:
- Click on each city's name to change location
- click on each weather icon to open the details window for the corrisponding city.
- Change current location
- Update weather (all)
- Change temp unit (all)
---FITS ON 1366x768 RESOLUTION---
windows_multi-weather_full_screen.xwp [3.5 MiB]
Downloaded 223 times
