It is currently June 14th, 2025, 9:52 am
 Post subject: Flourish Clock
PostPosted: April 7th, 2016, 2:43 pm
flourish_clock.xwp [175.97 KiB]
Downloaded 220 times
 Post subject: Re: Flourish Clock
PostPosted: April 25th, 2016, 11:18 am
Wow, beautiful widget! Thanks Jim!
One suggestion. It is not easy to tell the time at a glance, with this widget. Is it possible to resize the 'swirl' (the decorative pieces on the dial, that are linked to each other) so that each swirl will represent an hour? So instead of 8 swirls, you will have 12 swirls (one for each hour)? Does that make sense? If it is not worthwhile, no problems, this clock looks beautiful anyway! :)
My DeviantArt gallery: https://vee-kay.deviantart.com/
PostPosted: April 25th, 2016, 12:29 pm
Hi veekay. The swirls are actually random. But maybe I can create a v2 and add some more decorations under it for the hours. :)
Users browsing this forum: Bing [Bot] and 41 guests
