PostPosted: March 28th, 2016, 8:15 am
My Panzer clock and stopwatch widget.
This Panzer Widget (Yahoo widget version) can be downloaded here (the Xwidget version coming soon):
http://yereverluvinuncleber.deviantart.com/art/Panzer-Clock-and-Stopwatch-Yahoo-Widget-593080482
They are all free and open source, they need an engine to run. The yahoo widget engine and SDK is here: http://desktopwidgets.zenfs.com/4.5.2x1 ... _setup.exe
This shows the widget sized large, on a tank-themed desktop.
This shows the widget help page.
This shows the widget about us image.
File comment: Previously downloaded 90 times
tank_clock.xwp [3.91 MiB]
Downloaded 1278 times
PostPosted: March 23rd, 2018, 11:24 am
And for those that like to compare code, there is now a Yahoo widget version that is built using the same graphics and very similar code. The advantage of the Xwidget version is that it is much easier to build an Xwidget from scratch. The advantage of the Ywidget version is that it runs in its own discrete process and is more reliable as a result. It is also built using industry standard javascript.
You can get it here:
https://yereverluvinuncleber.deviantart.com/art/Panzer-Clock-and-Stopwatch-Yahoo-Widget-736825315
Widget also attached below.
PS. I've also updated the Xwidget version above so you can compare.
File comment: Yahoo widget version of the Xwidget clock/stopwatch
Panzer Clock Ywidget.zip [2.52 MiB]
Downloaded 1330 times
Users browsing this forum: No registered users and 189 guests
