It is currently October 23rd, 2026, 2:37 am
PostPosted: March 28th, 2016, 6:26 am
Disc Storage Widget, clicking on the top right button will replicate the widget so you can have one widget for each of your drives.
https://yereverluvinuncleber.deviantart.com/art/Panzer-Drive-Storage-Gauge-Xwidget-599465157
File comment: NEW version - the previous version was downloaded 83 times
tank_drive_gauge.xwp [2.62 MiB]
Downloaded 1349 times
Last edited by yereverluvinuncleber on April 1st, 2018, 4:56 am, edited 1 time in total.
PostPosted: April 1st, 2018, 4:46 am
I've updated the Panzer Drive Storage Gauge XWidget to make it less heavy on cpu usage and to allow the pointer animation effects to be switched off. You can download the latest version above.
I have also created a functionally equivalent duplicate storage widget for the Yahoo widget engine. The only advantage the YWE version provides is that it is a little more stable, uses less CPU when animating allowing you to have all the gauges running simultaneously with no system impact.
Best of all it allows you to compare the two engines and how things are done. The YWE allows uses of javascript API whereas the Xwidget version used cores available solely through the IDE.
Resizing is done through the use of CTRL+mousewheel up or down.
You can get the storage gauge here:
https://yereverluvinuncleber.deviantart.com/art/Panzer-Disc-Storage-Gauge-Yahoo-Widget-737565423
It is also attached below.
File comment: Latest version of the Yahoo widget of the Xwidget above, previously downloaded 6 times.
Panzer CPU gauge Ywidget.zip [1.95 MiB]
Downloaded 1221 times
