PostPosted: March 28th, 2016, 5:41 am
Now tested and working well - Ready to download now here: http://lightquick.co.uk/downloads/panzer-battery-gauge-xwidget.html?Itemid=264
Widget in full size (use mousewheel to resize up and down)
Widget About-Us image.
Widget in small size - approx 50%.
Widget in fullsize on a suitable tank-based wallpaper on a Windows 10 desktop.
File comment: NEW version - the previous version was downloaded 82 times
tank_battery_gauge.xwp [3.62 MiB]
Downloaded 1356 times
PostPosted: March 24th, 2018, 5:03 am
I have updated the above battery gauge widget and also created a Yahoo version of the same to show the differences between the two approaches. One uses a core that is bound to a rotator, the other has a pointer image with a central registration point that allows it to rotate. It is rotated by a javascript call to the Yahoo engine's battery API.
Another reason for comparing the Yahoo widget versions with the Xwidgets is to demonstrate how efficient the YWE animations are. When I am running 6 or 7 Xwidget gauges on the desktop with pointer animations turned on then there is a definite decrease in the desktop redraw response times, you can observe white shadows behind the desktop windows as you drag them. This does not occur using YWE animations and you can have multiple gauges on screen with no effect. I think this has to do with the monolthic nature of xwidgets all running in the same process, the effect of screen redraw over the Xwidget 'layer' has to compete for cpu cycles with running widgets. Tony should compare the two engines and look to improving that part of Xwidget.
File comment: Yahoo widget version allowing code comparison
Panzer battery gauge Ywidget.zip [2.07 MiB]
Downloaded 1364 times
Users browsing this forum: Bing [Bot] and 123 guests
