It is currently June 14th, 2025, 9:44 am
PostPosted: February 29th, 2016, 8:58 am
Based on "Real Desktop" windows program by Schillergames.
THANKS to meme who helped me with the "free shortcuts/save position" script.
Give a 3D look to your desktop with this full screen widget. 8-)
** 3 VERSIONS INCLUDED + 2 EXTRA WIDGETS **
1) Blue-Silver
2) Blue-Silver / custom bottom wallpaper
3) All-around custom wallpaper
4) Two extra widgets "StackFan" and "Hanging Shortcut" (original design by boyzonet/small mods by me) for more customization.
Right click for their options
TWO MODES:
- Steady shortcuts
- Free shortcuts (completely movable shortcuts)
Move and drag any shortcut anywhere on your desktop (!)
TWO BACKGROUNDS (except v3):
- Blue
- Silver
* Click on the wall-photo frame to go to the next picture.
* Mouse over the trash to show/hide the info. Double click to directly clear. Support for drag-drop
* Right click on each shortcut for the settings. Support for drag-drop for all the shortcuts.
---FITS ON 1366x768 RESOLUTION---
IMPORTANT NOTES:
1)TO REMOVE ANY CUSTOM CONFIGUrATION/POSITION OF THE SHORTCUTS (and retrsn to the default one) OPEN THE WIDGET'S FOLDER->"Config" FILE AND DELETE ALL ITS CONTENT.
2) Under "Free Shortcuts" mode, click on the edges (the mouse pointer will change) and move the shortcut S L O W L Y to the desirable position. Moving the mouse fast, maybe will cause some movement glitches. If you have any trouble with it press F5 to reload the widget.
3D Desktop Widget.rar [9 MiB]
Downloaded 313 times
